    Optimal settings to reduce battery drain when using VPN?
    Opera for Android
      padmakrishnadev last edited by
      Hello everyone, happy to join the community.
      I have recently switched to Opera for Android as my default browser (migrating from Chrome) because I really appreciate the built-in ad blocker and the free VPN feature. The browsing experience has been very smooth so far.
      However, I have a quick question for the veteran users here regarding optimization. I noticed that when I leave the VPN enabled, the background battery usage seems a bit higher than usual on my device (I am currently using a Samsung S23).
      • Does the VPN maintain a constant "keep-awake" state even when the browser is minimized?
      • Are there specific settings in "Data Savings" or specific opera://flags that you recommend tweaking to balance privacy and battery life?
      I want to keep the protection on, but I also want to ensure I am not missing any obvious configuration tricks.
      Thanks in advance for any advice!
