    Flow doesn't work between Opera One, Opera for Android and Opera Touch
      mmichel last edited by leocg
      Hello
      It's almost 3 years where I can't have Flow synchronize contents between Opera for Android or Opera Touch to Opera One Stable on Windows.
      Do we have a clear procedure to make it work ? And to report or investigate when it does not ?
      I recently started a clean profile for my laptop, so I'm at a loss understanding why it doesn't work, since it seems to be working for some.
      Thank you
        leocg Moderator Volunteer @mmichel last edited by
        @mmichel What exactly is not working ?
        By the way, Opera Touch no longer exists.
          M 1 Reply Last reply
          mmichel @leocg last edited by
          @leocg Opera Touch was nice, still working on my Pixel 6. Will ditch it, then.
          Opera for Android scans the QR Code, says "Follow instruction on the other device", but nothing happens on my laptop, the QR code hangs there.
            @mmichel I remember have seen reports about it. I just checked and got the same issue here.
              @leocg Should I file a bug report to add weight or just wait for a fix ?
                @mmichel It's up to you.
