    Opera One Not Syncing Speed Dial
      DaleKC last edited by
      Is it a known issue the speed dial is not synching?
      Is there anything specific I should try? I made sure that I have it enabled on both devices.
        leocg Moderator Volunteer @DaleKC last edited by
        @DaleKC So you don't see then in Other Speed Dials?
          D 1 Reply Last reply
          DaleKC @leocg last edited by
          @leocg Hi there - I am not sure what you mean. I have my speed dial on my desktop, which I was assuming would be synced over to my laptop.
          Maybe I am missing something.
          Thank you for your help.
            @DaleKC Nope, it doesn't work that way.
            You can see synced speed dials in Others Speed Dials in the bookmarks manager page, opera://bookmarks.
            You can copy the SDs you want from Other Speed Dials and paste them on Speed Dials to have them in the current device Speed Dial.
              @leocg thanks for your input. I was digging around online and found that Opera doesn't sync the speed dial the way I thought it would. I did want you said and copied and pasted.
