    Speed dial does not import.
      Vick77 last edited by
      I'm using Opera one 117.0.5408.93 on Windows 11.
      I'm changing my PC, in the older PC I export the bookmarks as always.
      But when I try to import in the new PC, only bookmarks bar is imported, the speed dial NOT, the speed dial stills empty.
      How can I solve this?
        If you goto the URL opera://bookmarks, look for an "other speed dials" folder or something like that. Look for it in the "bookmarks bar" folder too if you can't find it in the root of your bookmarks.
        If you end up finding the imported speed dials, you can select them and drag the selection to the "speed dial" folder.
          V 1 Reply Last reply
          Vick77 @burnout426 last edited by
          @burnout426 Found it:
          Inside the bookmarks bar I had some bookmarks, and a folder called: "Imported" and inside this folder another called "Speed dials" with all the speed dial links, I just selected all and drag to the Speed dial menu (at left), and the speed dial is restored now.
          Thanks for the help.
