    restore Speed Dials
    2848
    • espritarkitekt
      espritarkitekt last edited by
      I have an Opera GX account and had to get my PC laptop restored to factory settings to fix something, so I've been restoring everything from back up and I assumed that having an account on Opera GX would mean just signing in & everything would appear as it should.
      I found my speed dials saved in the bookmarks folder, but I don't know how to transfer or copy them from that folder onto the Opera GX start page.
      Please give easy-to-do instructions for a non-tech geek 🙂
        leocg Moderator Volunteer @espritarkitekt last edited by
        @espritarkitekt Go to the bookmarks page and copy them from other speed dials to Speed Dial
          espritarkitekt 1 Reply Last reply
        • espritarkitekt
          espritarkitekt @leocg last edited by
          @leocg thanks man!
          is this just the standard or only way to do it? coz i thought if u have an opera account and u sign in on another computer, it automatically syncs everything?
          coz the same thing that happened with my speed dials happened with the 200 opened tabs i had at the time of restoring my PC to factory settings, the tabs from 1 window show up in the Tabs section, the 2nd computer on the list... (see attached screenshot)
          but the tabs from the 2nd window seem to be gone forever & regardless, the tabs didn't restore to "this computer"...is that just how it is or....?
            @espritarkitekt It's the way to do that.
            Speed Dials are synced but not automatically populated in other installations, since people may want to have different Speed Dials in different devices.
              espritarkitekt 2 Replies Last reply
            • espritarkitekt
              @leocg ok understood, thanks
              • espritarkitekt
                sorry forgot to paste the screenshot
                  @espritarkitekt It's basically the same for opened tabs.
                  • espritarkitekt
                    @leocg well there's no copy/paste, so i just have to open all the tabs from my PC (before restoration) into the current browser?
                    • espritarkitekt
                      @leocg & is there any way of finding the tabs in the 2nd window which doesn't seem to appear in the tabs section i showed u?
                        @espritarkitekt Yep, that's it
