    Advanced Audio Equalizer
    22
    41
    21219
    • G
      gtnl7 last edited by
      Oh my god... This is the best Equaliser that I have ever had... I feel like I am in the cinema theatre. This is good... 5 stars for sure.
        viinylab 2 Replies Last reply
      • viinylab
        viinylab @gtnl7 last edited by
        @gtnl7: Hey, thanks a lot for your review - I'm thrilled to hear your positive experience
        • viinylab
            legoshimaster69 last edited by
            This is the best equalizer, a great tool and very simple to use. Thanks, 5 stars
              viinylab 1 Reply Last reply
            • viinylab
              viinylab @legoshimaster69 last edited by
              @legoshimaster69: Thank you so much for your review! i'm glad you find the UI easy to use. and Thanks again for the 5 stars!
              • viinylab
                viinylab @MarkusHeathcliff last edited by This post is deleted!
                • viinylab
                  @markusheathcliff: Thank you so much, we have fixed this issue in development and it will be shipped in next version soon, thank you for reporting
                  • viinylab
                    viinylab last edited by
                    We have released version V1.0.5 of our extension, which includes performance improvements and stability fixes. If you are experiencing crashes, please ensure you have updated to the latest version. If you are unsure how to force an update, simply reinstall the extension to resolve the issue. Thank you for your understanding.
                    • Sikmenq
                      Sikmenq last edited by
                      This is the best equalizer I have found yet, Fully recommend it.
                        pemguino last edited by
                        I've been using it for a while until now, when it suddenly stopped working. When I turn it on, all audio turns off. How can I fix it?
                        • Fikitty
                          Fikitty last edited by
                          really cool add, so handful
                            ElenaCabchuk002 last edited by
                            спасибо за расширение!
                              Sebalau last edited by leocg
                              I had a problem that needed fixing and now it's fixed ! This is an amazing help for listening to lectures recorded with a trash mic and chalk noises. (use compression + eq-out most of the highs and lows)
                              • rastanz
                                rastanz last edited by
                                Doesn't start with my browser or Youtube (Opera GX) I have to manually enable it. Removed!
                                • G
                                  gandalf1of9 last edited by
                                  Cannot see the full screen or scroll it from left to right leaving some of the equalizer controls out of my control. Removing it!
                                  • yrrh
                                    yrrh last edited by
                                    очень удобное расширение, классно, что так легко теперь можно настраивать звук на ноуте
                                      Cornelus-H last edited by
                                      Perfect ❤
                                        ebenezeralabanzas last edited by
                                        Excelente!! tiene de todo!!! es increíble que sea gratis!!
                                        • Chimzaaa
                                          Chimzaaa last edited by
                                          супер, очень нужная и удобная штука
                                          • Thabreadbed
                                            Thabreadbed last edited by
                                            Sometimes it gets bugged and can't initiate it,
                                            Not uninstalled!
