    Messed Up Installation Please Help! No Pubkey
    Opera for Linux
      Carl393 last edited by leocg
      So I accidentally installed the stable version instead of beta....hit CTRL + C half way through the dpkg (debian package) installation.. now I have this error message every time I do apt-update
      how in the heck do I get rid of this?
        S 1 Reply Last reply
        sorenfeodor @Carl393 last edited by
        @carl393 I would try following the instructions on https://deb.opera.com/manual.html. I imagine this (the first line, maybe) would install the right public key.
        If not, maybe try to uninstall opera and re-install (using timeshift before uninstalling if you have timeshift, so that you can go back if things turn sour)
          C 1 Reply Last reply
          Carl393 @sorenfeodor last edited by
          @sorenfeodor thanks! I managed to somehow export the repository address to a separate location and comment out the source (server where it indicates to download from) which fixed the issue.
