    Volume of Youtube videos randomly snaps to 100% when using Picture-in-picture
    3415
      bigkwii last edited by
      I usually have a video open with picture-in-picture and my 2nd monitor while I work or am playing a game, as background noise for the most part, so I usually lower the video's volume by quite a bit.
      Recently, I've noticed that at random, the volume snaps to 100%. I've tried to replicate it manually, but it really seems to happen at random. Although I've noticed that it happens more often when playing games.
      I have a feeling this isn't a bug pertaining to Opera GX itself, but rather something else going on with my pc or youtube. In any case, If anybody has encountered this same issue, I would really appreciate if you would let me know.
        leocg Moderator Volunteer @bigkwii last edited by
        @bigkwii Volume on video pop-out follows YouTube's normalized volume, so check if it's 100%.
          B 1 Reply Last reply
          bigkwii @leocg last edited by
          @leocg Yes, Youtube's volume also snaps to 100%
          This seems to happen when using the pop-up's volume slider. It seems to snap back to a previous volume setting it had for some reason. But I'm not sure. It's hard to troubleshoot this because it really seems to happen at random.
            @bigkwii But did you check in Statistics for nerds that normalized volume is 100%?
            Like I said, volume on video pop-out follows YouTube's normalized volume.
              @leocg Yup, that jumps to 100% too
                @bigkwii So that's it, if the normalized volume is at 100%, then the volume in video pop-out will be at 100% too.
                If you want to change the volume, you need to do it in actual video tab.
                  ryuuzk last edited by
                  yeah i'm having the same bug, i was with some live open in youtube in picture in picture mode, with the volume at 50%, then i pressed play at a random video on twitter and i lower the youtube to like 10% some seconds later just boom, back to 50%
