    Translate prompt on Right Click
    Feedback
    • hotepp
      hotepp last edited by
      Translate prompt on Right Click should already include the language you want to translate to (the default language you have your browser set to). Having to manually enter the language as a prompt everytime you try to translate something is counterproductive and makes the feature unusable.
        leocg B 2 Replies Last reply
        leocg Moderator Volunteer @hotepp last edited by
        @hotepp What right click? Unless I'm missing something, there is no translation tool on right click menu.
          hotepp 1 Reply Last reply
        • hotepp
          hotepp @leocg last edited by
          @leocg Sorry, my bad. It's a popup on text select.
          Example:
            @hotepp It should use the default browser language.
            • hotepp
              @leocg Well, it doesn't
                balagabi8 @hotepp last edited by
                @hotepp Thank you, very good.
