    Speed dial sync shortcuts/bookmarks issue
      fnzboi2643 last edited by leocg
      Whenever I edit or alter the speed dial shortcuts in my Opera GX browser, the Speed dial short cuts in my normal Opera browser get stored in a separate folder called "other speed dial book marks" and a new folder appears with no book marks in it and so the speed dial has no short cuts but when I go to shift all the speed dial short cuts in to my main folder the same problem happens on the Opera GX browser. [Happens only with Sync enabled]
      My problem is very specific and hard to describe but it annoys me pretty bad.
        leocg Moderator Volunteer @fnzboi2643 last edited by
        @fnzboi2643 Other Speed Dials is where you have access to Speed Dials from other Opera installations when you have Sync enabled.
        So if you change something in Speed Dial in an Opera installation, it's expected that the change will be replicated in Other Speed Dials
        That said, you are saying that if you change something in Speed Dial 1 in Opera GX, the same Speed Dial 1 in regular Opera disappears from the Speed Dial?
          F 1 Reply Last reply
          fnzboi2643 @leocg last edited by fnzboi2643
          @leocg Yep pretty much, and the change being replicated is not the problem it's the speed dials being shifted to a different folder or as you said it "speed dials dissappearing".
          Oh and the same exact problem happens when i alter the speed dial in the Regular Opera browser
