    [Duplicated]ffmpeg video decoder problem
    8950
      kinodegna last edited by
      Can't play most video in Opera on Windows 10 22H2 (everything OK in Chrome and VLC).
      in opera://media-internals/ I got "video decoder initialization failed"
      00:00:00.006	info	"Failed to initialize DecryptingVideoDecoder"
      00:00:00.007	info	"Failed to initialize WMFVideoDecoder"
      00:00:00.007	info	"Failed to initialize VpxVideoDecoder"
      00:00:00.007	info	"Failed to initialize Dav1dVideoDecoder"
      00:00:00.007	info	"Failed to initialize FFmpegVideoDecoder"
      00:00:00.007	error	"video decoder initialization failed"
      00:00:00.015	error	{"code":15,"data":{},"group":"PipelineStatus","message":"","stack":[{"file":"media\\renderers\\video_renderer_impl.cc","line":302}]}
      if video has audio then I got
      00:00:00.282	info	"Failed to initialize WMFAudioDecoder"
      00:00:00.283	info	"Failed to initialize FFmpegAudioDecoder"
      00:00:00.283	error	"audio decoder initialization failed"
      00:00:00.283	error	{"code":15,"data":{},"group":"PipelineStatus","message":"","stack":[{"file":"media\\renderers\\audio_renderer_impl.cc","line":648}]}
      Already tried settings and flags for hardware acceleration and re-installing.
      Thank you everyone for help.
        leocg Moderator Volunteer @kinodegna last edited by
        @kinodegna Do you have a N version of Windows 10 by chance?
          K 1 Reply Last reply
          kinodegna @leocg last edited by
          @leocg it's Windows 10 Enterprise 22H2 build 19045.2364 with Windows Feature Experience Pack 120.2212.4190.0
          Opera is 94.0.4606.54
            What do the video codecs section and audio codecs section at https://html5test.com/ say in Opera?
              kinodegna @burnout426 last edited by kinodegna
              @burnout426
              Video
              29/33
              video element
              Yes ✔
              Subtitles
              Yes ✔
              Audio track selection
              No ✘
              Video track selection
              No ✘
              Poster images
              Yes ✔
              Codec detection
              Yes ✔
              Video codecs
              MPEG-4 ASP support
              No ✘
              H.264 support
              Yes ✔
              H.265 support
              No ✘
              Ogg Theora support
              Yes ✔
              WebM with VP8 support
              Yes ✔
              WebM with VP9 support
              Yes ✔
              Same as in Chrome which has not the problem
                @kinodegna Seems OK. Do you have as couple of examples of pages where videos don't play correctly?
                  @leocg for example any mp4 file https://codeda.com/data/syncTest.mp4 or locally downloaded file:///D:/Downloads/syncTest.mp4
                    leocg burnout426 2 Replies Last reply
                    @kinodegna Video on that link played fine here on Windows 11. Will try to test on Windows 10 later.
                      @leocg thanks.
                      I have this problem in my Opera on every mp4/h264 video so far. And no problems with webm/vp8. For ex. if I convert the video to webm (https://codeda.com/data/syncTest.webm) I can play it in my Opera.
                      YouTube source is also OK https://www.youtube.com/watch?v=ucZl6vQ_8Uo
                        @kinodegna Does it work in Vivaldi or in another Chromium based browser that is not Chrome or Edge?
                        If you download the file, can you play it in Windows Media Player?
                          @leocg downloaded mp4 plays in Windows Media Player but Vivaldi 5.6 has same problem as my Opera.
                            So, you tried with hardware acceleration off at the URL opera://settings/system and you tried with hardware acceleration on while messing with the Angle flag?
                              burnout426 Volunteer @kinodegna last edited by
                              @kinodegna said in [Duplicated]ffmpeg video decoder problem:
                              That plays fine for me on Windows 11 Version 22H2 (Build 22621.1105) in Opera 94.0.4606.54 64-bit.
                              I do notice that with this particular mp4, it has opus for audio instead of aac. Not sure if that matters for Opera and Vivaldi's use of Windows 10's Media Foundation. Maybe though.
                                Also, could you provide the full opera://media-internals log?
                                  Following https://support.microsoft.com/en-us/windows/media-feature-pack-for-windows-10-11-n-september-2022-78cfeea5-c7d9-4aa8-b38f-ee4df1392009 anyway to see if that helps with playback of h.264 videos.
                                    K A 2 Replies Last reply
                                    @burnout426 I have already checked several times (and ways): all this N-version packages are not supported by my version of Windows 10
                                    Here is full log:
                                    https://codeda.com/data/media-internals.txt
                                    If you have some better mp4 for testing I will test on it
                                    Also tried all 5 variants in "Choose ANGLE graphics backend" and hardware acceleration in opera://settings/system and opera://flags/#disable-accelerated-video-decode and opera://flags/#disable-accelerated-video-encode
                                      @kinodegna Another question. Did this just start happening? As in, did Opera play mp4 files no problem until recently?
                                        What about the video-only ones at https://test-videos.co.uk/bigbuckbunny/mp4-h264?
                                          Try test standalone installations of regular Opera, Opera GX, Opera Beta, and Opera Developer. Just curious if any of them play mp4s for you. Guessing not, but...
                                            You can try this tool. There's an option under "Fixes" to reset the Media Foundation. You can try to see if that helps.
                                            Also, if possible, temporarily create a new local user account (not tied to a Microsoft account) on Windows, log into it and try Opera and Vivaldi there just to see if it works there.
                                            Could be a recent Windows update broke something with the media foundation configuration.
