    Connect Android to PC for My Flow
    Opera for Android
    annoying bad design neglected
      A problem trying to connect My Flow on my Android phone on Opera is very annoying, Especially when I see that it has been reported since the year 2020.
      The only thing that works is to go to: https://opera.com/connect
      Someone posted a workaround that does the job, but the bigger issue is, why haven't you fixed this where it works correctly? What's the point in having a piece of code in My Flow telling me to scan a QR code and having it just sit there doing nothing?
      I spent 19 years working for a computer company, and it appears no one has learned a damn thing since 2009. If you don't fix the annoying dumb problems in your software, you can have some users that are really angry or just leave.
      P.S. - This app you're using for the forum demanding that I drag and drop pictures without any assistance or explanation how to do it is also annoying. Everyone else simply has a place to click and a browser opens up with your pictures and you pick one. Why haven't you fixed this?Screenshot_20221013_074241.jpg
