    Your connection is not private problem
    4231
      Ves1c last edited by
      hi i have same problem for some sites i get this message
      https://prnt.sc/-FNzgYqeMlwZ
      and opera just wont lets me to the site saying its dangerous or something. I am sure that site is legit saying that in this case its from popular video game that i want to download.
      On some sites i have same message but i can just press something that allow me to go to site even when opera think its dangerous.
        A Former User @Ves1c last edited by
        @ves1c are you using adlock by any chance ?
          V 1 Reply Last reply
          Ves1c @Guest last edited by
          @ceedee i am using ad block thats build in opera but even if i turn it off its still show same messange
          https://prnt.sc/j9sR-GRrlfd_
            phongkyle545 last edited by
            This error is caused by an expired SSL certificate. You need to update the SSL certificate to a newer one. Watch the detailed video tutorial here:
            How to fix your connection is not private in opera
              which window you are currently using?
                Hey there!
                I have a HP Windows 7 laptop. when I open an authority site in my laptop browser. Show on my sacreen your conaction is not private. Can anyone I help me. And not play The Jumble Solver word unscrambler tool used to help users when playing word games or solving anagrams. Free and simple to use, Jumble Solver makes all possible words from the letters given. Use it to win Scrabble, WWF, or Crosswords.
                • temminckiiii
                  temminckiiii last edited by
                  The displayed error may be shown when your certificate setup is out of date - if you’re using Windows 7, you have to renew them manually (since Microsoft doesn’t support Windows 7 anymore). A lot of websites rely on those certificates for authentication purposes. Please check whether the DST Root CA X3 certificate is still valid on your computer, and if you have the new ISRG Root X1 already installed by any chance. You can do so by running certmgr.msc in the command line.
                  If you don’t have the ISRG Root X1 certificate set up yet, here’s a quick-how to:
                  How to setup the ISRG Root X1 certificate on Windows 7/10:
                  Download the .der ISRG Root X1 certificate file from https://letsencrypt.org/certificates/. If you can’t access the website, try downloading this file to a different machine, and transferring it (e.g. pendrive).
                  Click the downloaded file to start the installation process. (or left click and choose install)
                  Click install certificate.
                  Click “Next” on the next window
                  Select “Place all certificates in the following store”:
                  Click “Browse” and select “Trusted Root Certification Authorities”. Confirm the changes by pressing “OK” and “Next”:
                  Finish the certificate installation by pressing “Finish”:
                  You can press the Windows key + R to bring up the Run command, and type certmgr.msc and press Enter to open the certmgr.msc window and to check if the installation was successful (the ISRG Root X1 Certificate should appear under the Trusted Root Certification Authorities Certificate Store)
                  (You can download new DST Root CA X3 certificate replacement following the link in the same website.)
                  Discussed here: https://forums.opera.com/topic/51936/your-connection-is-not-private/11?_=1664018479978&lang=en-US
                    I have a HP Windows 7 laptop. when I open an authority site in my laptop browser. Show on my sacreen your conaction is not private. Can anyone help me. And not play The Jumble Solver word unscrambler tool is used to help users when playing word games or solving anagrams. Free and simple to use, Jumble answer Solver makes all possible words from the letters given. Use it to win Scrabble, WWF, or Crosswords.
