    MyFlow Connection problem
      Re: No Flow
      I have the same problem as in this post.
      I connect My Flow on PC via my cell phone using QR code. Both get a check mark, Connection is supposedly.
      Now when I send something from my phone to My Flow, on the PC the window just stays white. On the cell phone the message is inside My Flow.
      If I do the whole thing the other way around, i.e. from the PC to the mobile, it's exactly the same, it doesn't arrive at the other device.
      I have solved the connection several times now and it has brought nothing.
      Thanks!
