    Opera startup sound and animation
      hey i just downloaded opera gx to see how good it is.
      Its pretty clean and the personalisation is so good. But the startup animation and the sound what is does after restarting is annoying and way to loud.
      i want to disable it but i cant find a way to do it...
      browser sounds are the only sounds i can disable.
      (sry for my bad english im still learning)
        @skolas On Easy Setup you can disable the Start Screen on Startup (or something like that).
          arandomdriveruwu last edited by
          At features under browser music u can enable and disable the start up screen Splash screen on start up ur welcome 🙂
