    [Solved]Problem with twitter
    solved
      TatoJCM last edited by leocg
      Hi, I'm trying to login in Twitter, and it's not possible. Everytime I fill the user and password, the web refresh and ask for the information again. It doesn't show any message (like "the user name or password isn't correct"), I tried it in another browser and I was able to login.
      I search for information to solve this, but didn't find any. Also, last week, I was able to login just fine.
      Thanks for your help!
        leocg Moderator Volunteer @TatoJCM last edited by
        @TatoJCM Do you have cookies enabled?
          T 1 Reply Last reply
          TatoJCM @leocg last edited by
          @leocg Thanks! I tried that and it worked!
