    Opera Always active and draining battery
    Opera Mini
    5916
      I'm on the newest version and opera is my number one battery killer. Is it possible to deactivate opera when it's running it background without always deactivating the process manual in energy options?
        decrase very fassst !:😧
          You need to enable the battery saver located right next to the search and address field. Also, please disable the notifications about updates, recommendations, and usage reporting.
            @naheed thank you so much, I appreciate your answer but you are talking about windows, Android doesn't have a battery saver (unfortunately 😉
              ? 2 Replies Last reply
              A Former User @Guest last edited by This post is deleted!
                @santa24 said in Opera Always active and draining battery:
                Ahh.....yes it does have it.
                  @ryanb Opera Mini doesn't have the battery saver feature.
