    Discord Web is Stuck at "RTC Connecting" and Doesn't Allow Voice Chat
    discord rtc connecting opera gx bug issue
    41
    59
    178244
    • U
      upanotch last edited by
      #xscalamity you are a legend
        @xscalamity bro you fr helped me your so helpful
          TheBertt @Guest last edited by
          @unbeknownst Thank you so much friend, I was looking for a solution in forums, youtube and twitter but nothing doesn´t work, until I found your problem xd with that I finally solved my problem. GG!
            juggs @Guest last edited by
            @unbeknownst this post is old but i saw someone mention that turning of "
            Disable non-proxied UDP" fixes it, i tried it and it worked so incase anyone else comes here im just mentioning it incase it helps too
              @unbeknownst Thank you! This has worked for me.
                ananya10yt @Guest last edited by
                @unbeknownst Yes This Problem is with me also...
                I have also tried many Browsers like Microsoft Edge, Vivaldi, Epic Browser, But none of them suits Best for me/a Gamer...
                  @xscalamity You are The King, Legend, God for My Discord...
                  Thanks a Lot...
                    baolanevil @Guest last edited by
                    @xscalamity your my life saver
                      kamaleshswargam @quik last edited by
                      @quik Thankyou so much! It worked for me 🙂 I was struggling with this problem since last few months
                        MDLSonki @quik last edited by
                        @quik i love u bro u helped me i was wondering why it was stuck on rtc connecting
                          alazao @Guest last edited by
                          @unbeknownst thanks man,helped a lot!
                            nicolewis @Guest last edited by This post is deleted!
                              asdfqwerty last edited by
                              @XSCALAMITY thanks so much I was struggling with this for so long.
                                mikuchi @quik last edited by
                                @quik thanks man🙏🏻
                                  This worked! thankyou.
                                    Roachella last edited by leocg
                                    Discord RTC still connecting?
                                    guys i have the solution!!!
                                    1. Go to Opera Gx Settings
                                    2. Click Advanced
                                    3. Then click "Privacy and Security"
                                    4. Then scroll down until you see WebRTC, it's on top of VPN
                                    5. When you are on the WebRTC setting, you can see the it selected the "Disable non-proxied UDP" unselect it and switch to "Use any suitable network interface (recommended)"
                                    6. You go back to Discord and it's now fixed
                                      You're welcome!
                                    Reply Quote 5
                                      L T J R N 7 Replies Last reply
                                      silentknight1195 @Guest last edited by
                                      @xscalamity you have just saved my life... i was thinking about... touching grass.... but now i dont have to 😃
                                        @xscalamity thanks so much bro! I struggled with this for quite a while and it bugged me a lot so I am very glad I can now voice call while using opera GX as my browser
                                          mistyyy11 last edited by
                                          what about the app version? m on chromebook and its not there.
                                            littlewireredneck @Roachella last edited by
                                            @Roachella are you an angel.... thank you god ive been stuck useing the xbox app or useing a phone call for months now...
