    Speed dials missing after fresh install
    3151
      when i sign in to my profile after clean install of opera speed dials are missing for example booking ,youtube .amazon, ebay ,yahoo and facebook
        Hmm. Maybe before you log in, you can export your bookmarks. Then, when you log in, import your bookmarks, and maybe the default dials will sync. Then, start with a fresh profile again and log in to see if things work as intended.
          @burnout426 export them to where
            burnout426 Volunteer @Guest last edited by burnout426
            @thegeneral Goto the URL opera://bookmarks and use the drop-down at the bottom left to export the bookmarks as an HTML file to your desktop for example. Since speed dials are bookmarks too, they'll be exported too. Then, when you import them, if they don't automatically get imported into the start page, goto the URL opera://bookmarks and drag them from "imported bookmarks" to "speed dial".
            Or, on another Opera that you sync that has the speed dial entries, copy them to the speed dial folder on the other device in opera://bookmarks. (The other device being your other Opera that you set up fresh and synced.)
              Or, if you have to, see https://forums.opera.com/post/210210.
                @burnout426 all my bookmarks are messed up now
                  @thegeneral as in, duplicates or something else?
                    duplicates and it keeps creating folders
                      @thegeneral might to create a new account
                        @thegeneral You can goto sync.opera.com and reset your data if you have to. You might want to log out of sync, delete the duplicates and extra folders, and export your bookmarks first.
                          @burnout426 duplicates are only there when i sign in not when i sign out
                            @thegeneral 5b75f792-91d9-4f63-86a8-9c3ba3eb95b1-image.png when i create a folder in speed dial bookmarks that is what the speed dial looks like
                              I know the situation, when all speed dials are gone, especially after new installation.
                              You may want to try the following:
                              go to "O-Menu" > Bookmarks > Bookmarks and check if your speed dials are within another Speed Dial folder.
                              With each Windows (sometimes Opera) installation a new Speed Dial folder is created (the name of your computer)
                              For example, my computer is called "Home" and therefore Opera generates new "Home"-folders under "Speed Dial" / "Other Speed Dials"
                              Check, if your speed dial bookmarks are in one of these folders. If so, just delete the current dials and copy-paste your previous dials.
                                @celadyn yup your right but im not using opera at this meantime
