    Speed dial is the same across tabs
    • alobpreis
      alobpreis last edited by
      Now the Speed Dial seems to be the exact same instance across different tabs. If you open two tabs, and on the second one you scroll down and open a folder, if you then go to the previous tab (untouched Speed Dial), you will see the exact same thing. It will even make you think you didn't change the tab at all.
      Furthermore, in this scenario, if you open a link from that Speed Dial open folder and close any other tabs with a Speed Dial, when you open a new tab, the Speed Dial will load just as it was before: scrolled-down and with a folder open. For those who are developers, this looks like a singleton.
      This has started happening recently.
        Goto the URL opera://flags/#shared-start-page, disable the flag and restart Opera.
        • alobpreis
          alobpreis last edited by alobpreis
          Great, that did the trick. Thanks! For some reason I didn't think this configuration could be among the experimental flags. I wonder if this setting is temporary and in the future it will be impossible to undo this...
