    Grammar and Spell Checker - LanguageTool
    108
    119
    88533
      kubster007 last edited by
      I can't add This addon to sidebar 😑
        K L 2 Replies Last reply
        kubster007 @kubster007 last edited by
        @kubster007: I use Opera GX
          Very Cool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          It helps me a lot! But can you add grammar that would make a sentence very clear?
          • X
            xanman11 last edited by
            Works like a charm, but with some words, it doesn't spell check to add an accent, even though the word in that situation works only with an accent. Either way, works great, and I look forward to your continued work on this! If someone needs a good spell checking tool, this is THE one to get, even the free version works great!
              L 1 Reply Last reply
            • X
              One more thing, for some of the words it does need some more work with spell checking, but as it is it works great. When I say spell checking I mean with some words that have multiple correct forms, which change depending on the words around them.
                languagetool @kubster007 last edited by
                @kubster007: Sorry, it only works inline (underlining errors in the text) and cannot be added to the sidebar.
                  palx 1 Reply Last reply
                  languagetool @xanman11 last edited by
                  @xanman11: Thanks for your feedback. If you have specific cases that don't work, please let us know via email or by posting to the forum (https://languagetoolplus.com/legal/ and https://forum.languagetool.org).
                    Awesome extension. Works just as well as Grammarly without all the spying.
                    • vitani
                      vitani last edited by
                      Although it doesn't check enough mistake on my level, but I will still give 5 stars for their quick support. I got premium and their support is super effective.
                      • palx
                        palx @languagetool last edited by palx
                        @languagetool: It also doesn't spellcheck when you are writing in a sidebar app, like Facebook messenger for example and since the sidebar apps are all text communication services, it is were it is very much needed. Can't you try to find a way to implement that? Also when we have a sidebar app open and we translate a text from there, with the apps context menu. it opens it like it should do, to an active tab to the right, but now we have the upgrade prompt bezel in the way, so it obstructs the visibility of the spellchecked result. Maybe consider putting the upgrade prompt at the top or the right side of the page?
                          Bisher das beste Rechtschreibprogramm was ich bisher hatte, wenn uch geringfügige Fehler in Deutsch vor kommen. Erklärungen sind ein wenig dürftig. Beispiel da steht was von Kasus was bedeutet das keine Ahnung sollte mal besser erklärt werden. Würde ich mir wünschen. Ansonsten bin ich zufrieden Danke
                            akrynski last edited by
                            Początkowo ta wtyka wydawała się toporna, ale jak już się trochę z niej skorzysta, to staje się niezbędna i prosta.
                            • H
                              hvastaking last edited by
                              An excellent addition to the opera I often use even the grammar corrected!!!
                              • H
                                Harsh-15 last edited by
                                Yea, decent, good
                                  AALIen last edited by
                                  I've been used Grammarly that is more expensive for some time and LT is a better app for a reasonable price.
                                    johncovv last edited by
                                    Ótima extensão, me ajuda muito no meu dia a dia.
                                      I put this on my older computer and was surprised to see how bad my punctuation really is. It isn't always right but 98% of the time it is. I just put it on my new computer after about two weeks of not using it, I realized the auto-spell checker that comes with window/Opera wasn't doing a good job. I highly recommend it
                                        Love the fact that it helps with german grammar.
                                          angelo2008 last edited by
                                          This is totally better than Grammarly free
                                            sleepyuwu last edited by
                                            Ery' noice, i rate 6 transformers, out of 2 potatoes.
