    Yandex Zen flag does not work
    5663
      When I downloaded Opera GX (was the first version), I activated Yandex Zen flag. Ever since, I have never disabled the flag. After Opera 64 update in GX, I'm now seeing normal news. Can I fix it somehow? (I have enabled and disabled the flag, didn't work)
        @Bounty780 As far as I know, Yandex Zen is available just for some countries.
          @leocg I'm a russian. It should be available to me.
            I confirm! Opera GX LVL1 (core: 64.0.3417.139) does not show "Yandex Zen" news, although this feature is enabled in Opera settings and moreover , the flag for "Yandex Zen" is enabled, but news is still shown from "Opera" instead of " Yandex Zen"
            Windows 7
              @Bounty780 Did you choose to have Yandex Zen as news source in settings?
                ? ? 3 Replies Last reply
                @leocg The bottom line is that "Yandex Zen" is enabled everywhere, but does not work. Instead, it shows news from "Opera"!
                  @leocg I did!
                    @leocg Should I send a "bug Report" on this issue or will the developers see this bug here anyway?
                      The behavior is the same with a clean profile?
                        ? ? 2 Replies Last reply
                        @leocg said in Yandex Zen flag does not work:
                        Yes, I just created a clean profile to check.
                          @leocg can you suggest us anything?
                            @Bounty780 Probably a bug in GX. In regular Opera, it seems to work.
                              @leocg no, like a temporary solution?
                                leocg ? 2 Replies Last reply
                                @Bounty780 There isn't one that I know of.
                                  @Bounty780 Did you set (opera://flags/#yandex-zen-news) to Enable?
                                    A Former User @Guest last edited by leocg
                                    @PeterBurton A while ago.
                                      Re: Yandex Zen flag does not work
                                      It's essentially a bump, but the Yandex Zen still doesn't work, even after so many updates. Opera newsfeed replaces Yandex Zen, even if it still is chosen.
                                          alperdurukan last edited by
                                          Still waiting for this to be solved, I do not want to switch back from the GX.
