    add-on bug, need help
    • stop--it
      stop--it last edited by stop--it
      Hi, my Opera extension block access to url's, problem is my extension Block urls but i still can go to the index homes pages, so here it's a part of my code, need help to understand what's wrong and how i can correct that.
      also profanity words are not blocked Safe Search is off, but why !!!
      Here the code of my search.js
      "use strict";
      chrome.webRequest.onBeforeRequest.addListener(
      redirect,
      {urls: ["<all_urls>"], types: ["main_frame", "sub_frame"]},
      ["blocking"]
      chrome.webNavigation.onReferenceFragmentUpdated.addListener(function(details) {
      if ( /webhp.*q=/.test(details.url) ) {
      let new_url = _add_if_necessary(details.url, "safe=active&ssui=on");
      if ( new_url ) {
      chrome.tabs.update(details.tabId, {'url': new_url});
      function redirect(requestDetails) {
      let redir_url = _alter(requestDetails.url);
      if ( redir_url ) {
      return { redirectUrl: redir_url };
      function _alter(uri) {
      if ( uri.indexOf("google.") != -1 ) {
      if (/q=/.test(uri)) {
      return _add_if_necessary(uri, "safe=active&ssui=on");
      } else if ( uri.indexOf("search.yahoo.") != -1 ) {
      if (/(\/search)/.test(uri)) {
      return _add_if_necessary(uri, "vm=r");
      } else if ( uri.indexOf("bing.") != -1 ) {
      if (/(\/search|\/videos|\/images|\/news)/.test(uri)) {
      return _add_if_necessary(uri, "adlt=strict");
      } else if ( uri.indexOf("duckduckgo.") != -1 ) {
      if ( uri.indexOf("q=") != -1 ) {
      return _add_if_necessary(uri, "kp=1");
      } else if ( uri.indexOf("yandex.") != -1 ) {
      if ( uri.indexOf("/search") != -1 ) {
      return _add_if_necessary(uri, "fyandex=1");
      return false;
      function _add_if_necessary(uri, needed_part) {
      if (uri.indexOf(needed_part) == -1) {
      return uri + "&" + needed_part;
      } else {
      return false;
      chrome.webRequest.onBeforeSendHeaders.addListener(
      function(details) {
      for (let i = 0; i < details.requestHeaders.length; ++i) {
      if (details.requestHeaders[i].name === 'YouTube-Restrict') {
      details.requestHeaders.splice(i, 1);
      break;
      details.requestHeaders.push({"name": "YouTube-Restrict",
      "value": "Moderate"});
      return {requestHeaders: details.requestHeaders};
      {urls: ["*://*.youtube.com/*"], types: ["main_frame", "sub_frame"]},
      ["blocking", "requestHeaders"]
      here my background.js file
      'use strict';
      let db = []; // session Global
      // ----- parse & cache the database data
      fetch('http://website/upload/db.dat')
      .then(response => response.text())
      .then(text => { db = text.trim().split(/[\r\n]+/); })
      .catch(error => console.log(error));
      chrome.webRequest.onBeforeRequest.addListener( details => {
      let url = new URL(details.url);
      return { cancel: url && url.hostname && db.includes(url.hostname) };
      {urls: ["http://*/*", "https://*/*"]},
      ["blocking"]
      • stop--it
        In fact my add-on works BUT i found something interesting !
        How in my add-on code i can activate all those functions by default ?
          leocg Moderator Volunteer @stop--it last edited by
          As far as I know, you can't.
            stop--it 1 Reply Last reply
          • stop--it
            stop--it @leocg last edited by
            @leocg well it has to be a way to solve this, i just want my add-on block the urls !!! problem is something doesn't work in my code and i have access to the index pages of blocked sites url's !
