    Problem signing in after moving roaming profile
    14400
      @vince42 Try checking if opera://sync-internals/ gives you any hint on what may be happening.
        Try 'n to do what you're try ' n to do immediately kills all "metro" applications and components and disables Start Menu. And win 10 updates may not work + uninstalling n e progs.. manual.. If not done right..
        if you was gonna move 1 or 2 folders from roaming would be safer i guess.. Are you running outta room on that drive..
          Try to check the installer_prefs.json file, and change the profile type from false to True.
          "You cannot know the meaning of your life until you are connected to the power that created you". ยท Shri Mataji Nirmala Devi
            @nvmjustagirl said in Problem signing in after moving roaming profile:
            I am doing this for a living, trust me: it works, nothing is broken - you just need to know what you do and you're fine.
              @leocg @zalex108 those are both promising tips, thank you - will check that out.
                @zalex108 said in Problem signing in after moving roaming profile:
                I switched from false to true, started Opera and were able to start the synchronization. All bookmarks, settings etc were gone though.
                Then I switched back to false, were able to log in and at least my bookmarks and settings came back. My passwords seem also to be restored now.
                Thank you for this hint!!! 1,000 Kudos!
                  zalex108 1 Reply Last reply
                  @vince42
                  ๐Ÿ™‚
                  ๐Ÿ‘
                    @vince42
                    ๐Ÿ™‚
                    ๐Ÿ‘
                    hug ๐Ÿ˜‰
                      Topic closed as solved. If in up until to a month the author needs the thread to be reopened, just report it. briefly explaining the reason.
