    Flash player does not work; can not be able.
    162
    221246
      @shahramop said in Flash player does not work; can not be able.:
      @zalex108 Thanking you, but the website tells again"You need to install or allow Adobe flash to play the games.
      Please click the "Get Adobe Flash Player" link below to install or allow Flash" meanwhile I have already either installed and enabled the flash player.
      Go to your Windows Control Panel and double click the "Flash Player" option. When the applet opens, click the "Updates" tab.
      Do you have a "PPAPI Plug-in Version" listed there at the bottom?
      If not, there is no way Flash will work with Opera.
      馃檪
        zalex108 1 Reply Last reply
        @davehawley said in Flash player does not work; can not be able.:
        馃檪
        Finally
        We all one forgot about that. xD
        Opera Stable 路 Beta 路 Developer
        Test profile | Back up Linux 路 Mac 路 Win
        "You cannot know the meaning of your life until you are connected to the power that created you". 路 Shri Mataji Nirmala Devi
          Thanking you, I have already done it; I have PPAPI Plug-in version, I posted its screenshot here down.0_1510788202810_Opera Falsh Player Problem Window FPlayer.png
            ? acidinmyfridge 3 Replies Last reply
            @shahramop
            Well that looks fine, so it's a bit of a mystery why it's not working!
            Does it work on the tests here -
            http://www.chemgapedia.de/vsengine/help/en/flash/index.html?
              @davehawley Thanking you, No, the Flash Player does not work in the above test link, telling "Flash not running".
                @shahramop Even adding the site as an exception in Settings > Sites > Flash it doesn't work?
                  @leocg Yes, I did it using "allow" option, but the problem exists and the flash player does not work, its screenshot is as following.
                    @shahramop Did you try a full clean reinstall of Opera? Did you try un-installing and re-installing Flash?
                      @leocg yes, on one of my PCs, both my PCs has the above problem, I fear that the problem refers to Opera itself.
                        @shahramop What is strange is that Flash works fine for many others.
                          @leocg One of my friends has confronted with the same problem!!
                            Have you tried with a new clean Opera profile?
                              @davehawley Thanking you, I have already carried out a "clean" uninstallation(including deleting it in registry) and re-installation, I do not how to make"new clean opera profile"but I fear to lose my bookmarks and account that are important for me, today there was a new opera version, I downloaded it but the above problem exists, before I did not have such problem; I have this problem in both of my PCs, only in Opera, in other browsers flash player works fine.
                                @shahramop
                                Doing that may not actually have deleted your old profile, and there could be something in there that is causing the Flash problem.
                                Go to "About Opera" and see there where your profile folder is.
                                Go to that folder in Windows Explorer and, with Opera closed, rename it adding .old to the end of the name.
                                Then restart Opera which should then create a new clean profile in the same place.
                                See if the Flash problem is still there on the sites it was failing on (you will not have your bookmarks so you will need to put the addresses in manually).
                                If it's now working, there is something in your old profile stopping it working, which obviously needs to be investigated.
                                If it still isn't working, close Opera and go to the profiles folders again, delete the new folder and rename your old one back again and everything should return to as it was before.
                                馃檪
                                  @davehawley Thanking you I did your instructions, but the problem exists, after changing the profile, adding the "old"to it (Opera Stable Old)there was a new opera without my old bookmarks, I tried flash player in different websites , but it did not work, and so I came back to my opera, deleting new folder (coming back to the same Opera Stable).
                                    @shahramop
                                    You was almost got it..
                                    To Allow add a site.. just go up to green lock and right click it scroll down to flash and click always allow on this site.
                                      Can you delete all the flash exceptions, close out of the dialog, close Opera, start Opera back up, add the exceptions this way:
                                      [*.]opera.com
                                      [*.]bbc.com
                                      [*.]radiohambastegi.se
                                      [*.]adobe.com
                                      [*.]zigiz.com
                                      [*.]othersite.com
                                      close out of the dialog, restart Opera and then see how it works?
                                        @nvmjustagirl Thanking you, when I click on the "enable Flash" option, on the flash image, nothing happens, Flash player can not be enabled.
                                          Go back to page ...if you see this image saying flash is installed that means thingy will show it shows maybe 1 sec if that.. unless adblocker could be messing it up
                                            @burnout426 Thanking you, I did it, but the problem was not fixed.
                                              ? burnout426 2 Replies Last reply
