    Sync between devices not working
    Synchronization
    14
    31
    18940
      thecrater last edited by
      Hey guys, I'm using encryption with my synced data. I cannot get open tabs to sync. I use opera desktop for Windows, Opera for iOS and Android (not Mini). What's the issue? I've got a tick next to Open Tabs but not passwords which I don't want to sync.
        Just to add that https://sync.opera.com/web/ is showing 0 tabs but I can't figure out why that is?
          What's the issue?
          Synced data encryption only works in desktop version of Opera.
            But it doesn't work between the desktop versions either. I have one at home and one at work and it won't sync tabs between them either!
              So the tab menu doesn't show the tabs opened in the other Opera installation? None of them show the tabs of the other one?
                mallyone last edited by
                Nothing is syncing across devices
                What are those devices?
                In my case, it is PCs - desktop and two laptops. Not even thinking of trying with my Android devices til the PCs are in sync. I am not using the encryption password option. All I want to sync are the bookmarks and extensions but it is not happening. Chrome was instantaneous... why is this not working for Opera?
                  And nothing syncs?
                  • G
                    greentraderr last edited by
                    Same here. Been using Opera for a couple of months because Google Chrome kept crashing. Has some advantages, but the absence of sync is a major pain. If Opera isn't interested in fixing it, I'm back to Google.
                      Same here
                      That meaning....?
                      Opera has sync.
                      Well, the world will not care or change if you do it.
                        lortigosa last edited by
                        Hello
                        It's so basic, how can it be possible that they're not fixing it? I need to sync 😞
                        Is there any way to contact them... which they would answer?
                          This topic turned into a mess.
