    ecosia or ixquick as default search engine
    • W
      wolkenatlas last edited by
      Is there a possibility to use ecosia or ixquick as default search engines? Is there any reason why one restricts to the standard ones?
      Thanks in advance
        mariwi last edited by
        Same question here: Is there any way to add new default search engines myself? If not via the settings, would it be possible to do this via a plugin?
          You can add search engines but you can not set them as default ones
