    Custom icons and sidebar edge
      longlife777 last edited by
      • Possibility to change icon/image of the speed dial site and same for bookmark bar folders.
      • It would also be cool if you could bring back "Show panel toggle at edge of window" (for the sidebar) feature back.
      I don't really like those folder icons on the bookmark bar and I think that It would be cool if we had option that could allow us to change it.
      Speed Dial custom icons...some sites have their own icon/image and some don't (most of them don't) it would be pretty neat if we had option to customize them.
      Sidebar edge toggle is just something that I miss from old Opera...Sometimes I'm just to lazy to reach out to my keyboard to open the sidebar.
        It's already possible.
          james438 last edited by
          More detail please. How is it possible to change the speed dial icons?
          To change the size you can use ctrl+mouse wheel. To change the icon image you can use the heart menu located within the address bar on the right side of it to set the image. Or were you asking about something else?
            Is possible to change speed dial icon ? Opera has that option integrated ?
              Open the page and use the heart menu.
              Really not intuitive, but it works. (In O32 you an also zoom the screenshot with your mouse wheel, if you select that image.)
