    I need Help with opera
      ackir last edited by
      hello guys, im new in opera browser im using opera19 and i have the option import favorites disable! i try search in google how i enable this option but i don't find nothing! i have a lot favorites in bookmarks bar and i need a backup can someone help with this? i appreciate any help 😉
      Greetings
        There's not yet any option to import bookmarks from other browsers, although there's a workaround for Chrome.
        If you install Opera 12.16, you can import your bookmarks to that — it's a much better browser in most respects, with more features and more configuration options. If you then install Opera 19, your bookmarks will be available and can be imported to the Speed Dial or Bookmarks Bar (enabled in Settings).
        http://www.opera.com/download/guide/?os=windows&ver=12.16&local=y
          Hello, thanks a lot for your answer, i can import my chrome favorites to opera i do a manual backup from bookmarks.bak in chrome folder and put in appdata>roaming>operasoftware>operastable and it work fine but now i cant do a backup directly from opera the option is disable!this version is bester dan opera19?
          thanks 😉
          "sory ma bad english!" 😕
          "edit" i install opera 12 and i have the option to import my favorites but when i do import favorites from firefox i select my file but dont appear nothing in bookmarks bar! do you now why this apend?
            If the bookmarks imported successfully to Opera 12.16, they should appear in the Bookmarks Menu and the Bookmarks panel. From the panel, you can drag folders onto the Bookmarks Bar.
