    Volume Booster — Enhance sound
      Here you can post comments about Volume Booster — Enhance sound extension, created by d54e1bfc-3f02-4048-a1b0-6d29d9b20f02
        tewible-gamer last edited by
        works as said allows you to boost or decrease the sound of any tab, makes it really useful for having a bit of quite audio in the middle of you game instead of dealing with youtube's sensitive audio slider
          caydemlebahtiyar last edited by
          Was using Volume Booster for months now its done for some reason and this one is cleaner ALSO doesnt prevent you from going full screen thank you
            lind39 last edited by
            sooo useful while watching videos
            • O
              Onvrax last edited by
              Unfortunately, this Opera extension is very disappointing. It's supposed to be an audio extension that lets you increase the volume, boost the bass, and adjust the sound for each tab. This sounds very useful, especially for YouTube or music.
              However, in practice, it doesn't work reliably at all. Every time you close another tab, the add-on deactivates itself. This is extremely annoying, especially if you have a YouTube tab open and the sound is suddenly reset.
              Such a fundamental flaw shouldn't occur, especially with an extension specifically designed for audio and offering features like significantly increased volume or bass boost.
              As it stands, it's not enjoyable to use and feels completely unfinished. It would be highly desirable if this problem were finally fixed so that the extension runs stably and reliably.
                ModiusX last edited by
                I hate it, the first volume boost extension that not keep the volume set when I pass my Netflix episode, even worst, desactivate the volume boost when I pause my cap. Incredible
