    Speed dial folders are way too dark (opaque) in the v27
    3363
    • tisme
      tisme last edited by
      This is how 'Speed dial' start page looks in v27, now you can't see icons in the folders (you could in v26):
      v27 Speed dial
      Also, I don't like the horizontal placement of new 'WebUI bar' -- it wastes too much. Is it possible to to force it be vertical (either left or right, doesn't matter) or switch it off altogether (in view of little usefulness)?
      And the last one: how to disable 'Discover' feature, or at least remove any notion of it from the browser. (I do know how to discover things myself.)
        dewired last edited by
        About start page folders - same here. Any soulutions?
          Go into opera://flags and change the setting to use the other speed dial.
          • tisme
            Could you please, name exactly "the setting"?
              Experimental start page. Just type that into the search box, change the setting and you should be good to go.
              • tisme
                No need for 'opera://flags' in this case: there's a button in lower right corner of Start page which switches it. Unfortunately, unexperimental start page looks even more ugly than experimental one (even with v27's opaque folders). It used to be fully OK in v26.
                  Same here, any suggestions?
                    capo315 last edited by
                    Yes, has anyone found a solution to this yet?? The start page looked so much better before, I've had to take all my links out from their folders.
