    [Site Issue] Twitch.tv doesn't work/fully functional in Opera
      MonthOLDpickle last edited by
      Chrome and Firefox (even IE) twitch.tv works flawlessly for the most part..sometimes a quick refresh fixes it.
      But on Opera I can get the video working half the time, but the chat NEVER loads. I can't figure out why.
      Any work-arounds?
        stng last edited by
        Try Opera 12.14
          Does that require a downgrade? If so..how?
            It requires a Download.
            You can run multiple Opera versions simultaneously. Install in different folders — I use the USB install option to keep profiles together with the installation folder.
              Is there anything to worry about a stock 12.14..running really slow?
                stng last edited by
                Maybe. But, in fact, 12.15 and 12.16 has a web-site compatibility issues.
                No. 12.14 is a way better.
                Don't forget to disable update warnings (opera:config#UserPrefs|DisableOperaPackageAutoUpdate = enable).
                ETA: http://www.twitch.tv/directory broken in 12.16(x64, Windows).
