    Opera fonts are too light
    Opera for Linux
    3560
      ar-k last edited by
      Several fonts in Opera are too light to see. As I am typing in this form the font is light gray on white background. The address bar is also light on white background and I can't change the color in font settings although I can change the font and font color. Is there a workaround?
        ar-k last edited by
        BTW I use Opera Next Beta on GNU/Linux.
          Which Linux distrie, which Windowmanager, which systemfonts?
            Yes, the font color in forum is not really black; it is RGB(64,64,64), in hex #404040
              ar-k last edited by
              Debian GNU/Linux Jessie, (OpenBox using a dark theme)
                ar-k last edited by
                Problem solved with new theme.
                  subhuman last edited by
                  nevertheless this shouldn't have happend in the first place. it can't be that the window manager determines in which way a program renders the contents it displays. that's none of the wm's business.
                  hence i assume that by changing the wm's theme you accidentally "repaired" the original problem.
                    edit: i just realized that you're running jessie. for a system in a "testing" state i'd suppose a problem with fontconfig rather than one with openbox or opera. maybe a look at bugs.debian.org will reveal something of relevance to your problem.
