    Opera Flow confirmation code not showing on desktop
    flow
    54
    66
    55280
      Christianfyp @TerrorFox-Tech last edited by
      @terrorfox-tech Oh man!!! this fixed my problem! thank you very much for your help!
        SimonTP last edited by
        Finally working , using your procedure, Thanks.
        now i do have to find the way to restore Bookmarks to the right place, because it keeping going to bookmark bar instead of bookmarks and speed dial.
          sharkalone last edited by
          @terrorfox-tech merci beaucoup. You're a digital lifesaver as of now!
            Toby-Toby @gracetheartist last edited by
            @gracetheartist Following, as I have the same issue
              mstfcbngl last edited by
              It's happening a lot lately. Usually it's work again after at least one day but this time it's still not working.
                bitterblackale @TerrorFox-Tech last edited by
                The Answer
                go to https://opera.com/connect instead of connecting with the sidebar.
                @terrorfox-tech This is (for now) the answer until the sidebar method is fixed. Thank you.
                  R 1 Reply Last reply
                  fuel0013 @TerrorFox-Tech last edited by
                  @terrorfox-tech thank you so much! I have been trying to figure this out for months!!
                    chkarthiksai1998 @gracetheartist last edited by
                    @gracetheartist
                    i am also facing the same problem with conformation 6 digit code where to enter it always redirects to opera account page, i thing its probably a glitch or a technical bug which need to be addressed by OPERA.
                      C 1 Reply Last reply
                      Christianfyp @chkarthiksai1998 last edited by
                      This was resolved by @TerrorFox-Tech months ago. His solution was "I had the same problem but was able to work around it. The key was to not do this through the sidebar. When connecting to flow on the phone you get to the point where you have to scaqn a QR code. The QR-code is not the same QR code as in the sidebar on desktop. Instead enter opera.com/connect in a new tab on the desktop. There is a QR code which is compatible with your phone setup. After scanning this QR code it should show the same 6 digits as on the phone. Acknowledge on the desktop tab they are the same"
                      Reply Quote -1
                        DeanW22 @TerrorFox-Tech last edited by
                        @terrorfox-tech , thanks that did the trick
                        Reply Quote -1
                          Musfiq001 @TerrorFox-Tech last edited by
                          @terrorfox-tech Thank you so much.
                          Reply Quote -1
                            bambast last edited by
                            It's horrible. Flow just doesn't work for me. I scan the qr. Code is the same, then I get: "Can't connect, PC turned down the connection."
                            Not given any solution or anything. And there is nothing you can do.
                              ajelandrop @Christianfyp last edited by
                              @christianfyp I have been using this method for a year now because the qr code and opera flows still don't ask me for the verification code. When are they gonna fix it?
                                AzithromycinZih @TerrorFox-Tech last edited by
                                @terrorfox-tech it worked! thank you very much
                                  suikoy last edited by
                                  It's very strange but I'm not able to complete the autenthication.. My android smartphone shows the 6 digit confirmation code but in the meantime the desktop jumps to https://auth.opera.com/account/v3/desktop/login/login-success...
                                  This behaviour in both cases: with the QR code from the Flow panel or with the QR of the site opera.com/connect.
                                  And the even strangest thing is that if I use Flow with my iPad everything works perfectly.
                                  Perhaps it is a clue that the bug with Flow is caused when both the desktop PC and the Android smartphone are already connected with the same Opera account.
                                  Any suggestions?
                                  Reply Quote 6
                                  • I
                                    iiolavoii @TerrorFox-Tech last edited by
                                    @terrorfox-tech Hi there,
                                    After reading the QR Code, I'm not able to type the code anywere ¯_(ツ)_/¯. Browser says I've succesfully loged in, but the Android phone says the oposite. Can you help?
                                    Reply Quote 6
                                      Chri-73 last edited by
                                      Hi all,
                                      I have the same problem as suikoy and iiolavoii.
                                      Some times (means some years) ago I somehow could connect desktop and my phone. It worked for a long time now.
                                      But today somehow the connection was lost.
                                      And if I try to reconnect my phone (even if I scan the code from the mentioned homepage instead of the sidebar) after scanning the android smartphone shows the 6 digit confirmation code but the desktop jumps to "https://auth.opera.com/account/v3/desktop/login/login-success".
                                      There is shown "Congratulation, succesfully logged in" and the question "What do you like to do now" with the 2 buttons "Your data is synchroniced" and "Manage subscriptions". That's all.
                                      Meanwhile the code on the phone times out and then I can restart the whole procedure...
                                      I would be grateful for help.
                                      Reply Quote 3
                                        Z 1 2 Replies Last reply
                                        mstfcbngl last edited by mstfcbngl
                                        It's just so irritating still have this problem after all that comments and all those new version of browser.
                                        • Z
                                          Zacatk23 @Chri-73 last edited by
                                          @chri-73 That exactly has been happening to me since a coulpe of weeks ago, man I really need flow
                                          • 1
                                            1Socratic9 @Chri-73 last edited by
                                            @chri-73 Same Issue, I explored both options it gives, "Synchronize your data "and "Manage your subscriptions", neither option seems to give anything related to the code on the android Opera app. Would be nice if the QR scanning worked properly to avoid this whole mess.Screenshot 2024-02-29 130917.png
                                            Reply Quote 4
