    GX Lights not working with G Hub
      coltonp311 last edited by
      I have G Hub installed on my PC with my Logitech G203 mouse but in GX Lights, it says G Hub is not found on my PC.
      Proof i have G Hub:
      If anyone knows how to fix, please tell me!
        reasonablepsycho last edited by reasonablepsycho
        The Logitech drivers are an absolute mess (tried writing an app for them, believe me...), so this might not work at all. But you should try combining things.
        • First, the settings (sorry for the lack of polish).
        • Secondly, try reinstaling the drivers themselves and messing around with them. (versions, etc.).
          F 1 Reply Last reply
          FiyaFly @reasonablepsycho last edited by
          @reasonablepsycho While I'm not the original poster, I am also having this issue:
          However, I do not see an integration option for Opera GX:
          When you say drivers, do you mean the software, or the drivers for the devices that the software controls? To clarify a bit, I have attempted:
          • Reinstalling GHub with Opera GX installed
          • Reinstalling Opera GX with GHub installed.
          Neither of these seemed to affect the result for the integration.
          Reply Quote 3
            M 1 Reply Last reply
            MidgetOfDeathV1 @FiyaFly last edited by
            @fiyafly I'm having this exact issue, no updates are helping on this, been playing with my drivers and restarting etc. still nothing.
