    No menu when clicking right button..
    Opera for Linux
    menu
    20
    51
    41215
      pgper last edited by
      Same here,
      Opera Version:92.0.4561.33
      Ubuntu 22.04.2 LTS
      Minimizing and maximizing helps.
      Bug occurring after a while a video has started playing
        A Former User @pgper last edited by
        @pgper They arent going to fix it. If they were going to fix it, they would have already done so. There are threads about this all over the place. This thread itself is almost a year old.... and still no fix. One of the reasons I stopped using Opera
          The issue seems to happen when you maximize a youtube video, switching to full screen video, and afterwards you restore the video, exit full screen video.
          So maximizing and restoring the size of the video is where someone should be looking.
          Minimizing and maximizing the opera window will solve the problem until you maximize another video, enter full screen video. Or you can switch to another program and back to opera.
            ? P 2 Replies Last reply
            @idsantos it does it regardless of playing a video. I removed Opera long ago due to it always being broke and not fixed. Got curious recently and did a fresh install of 99.0..4877.9 with virgin profile. Had right click/menu issues immediately when it opened. Plus the video issue was still broken, even crashing pages that contained video. Inexcusable!
              @silverfox66
              I am running opera version 99.0.4788.13 on Opensuse Leap 15.4 (kernel version 5.14.21-150400.24.63-default ) on a fresh install. My pc had windows 10 for some work related stuff which I am done with, so I install Opensuse Leap 15.4.
              The main issue which I have experiecing is the right click issue as described in the original post.
              The reason which I posted the message was because I felt that I had found a way to trigger the issue so hopefully someone at Opera can solve the issue.
                M ? 2 Replies Last reply
                markinaustin @Guest last edited by
                @idsantos The Opera Developer [beta of the new Opera] works smooth as silk.
                  ? ? 2 Replies Last reply
                  A Former User @markinaustin last edited by
                  @markinaustin said in No menu when clicking right button..:
                  You need to clarify.
                  Why, because there is an Opera Developer version AND there is an Opera Beta version. Each version is different.
                    M 1 Reply Last reply
                    @idsantos said in No menu when clicking right button..:
                    @silverfox66
                    I unserstand your reason. My reason was that it does it on a virgin install, upon first running it, with zero parameters triggering it
                      people shouldnt have to run beta/developer versions to avoid a broke software. Thats the whole point of a "stable" release
                        @myswtest
                        Got it. Opera Developer.
                          pgper @Guest last edited by
                          @idsantos Not the video but the window. When I click minimize (the windows) and then restore it, right click behaves normally.
