    CookieBlock
    7
    7
    2407
      Here you can post comments about CookieBlock extension, created by cookie-block
        Doesn't work.
          Unfortunately, Opera has not yet reviewed our submitted updates for our extension, preventing us from fixing problems and adding features. The 1.0 version is available on Opera Next and Opera Developer however.
            B 1 Reply Last reply
            Billystorm @Guest last edited by leocg
            @cookie-block
            well is it working now? almost a year later?
            i wish at least ONE of these things would actually work the way it's intended, and the way the creator says it will.
            i just want to be able to block certain cookies and not just for a "session" but forever.
            i can go through and manually enter "block" on each line-item e.g. "javascript", etc, but that's a real pita.
              Muttat1on last edited by
              (Still) doesn't work.
              • N4i75irHc1371
                N4i75irHc1371 last edited by
                Questa estensione mi impedisce di fare il login su Aliexpress anche se ho aggiunto il sito nelle eccezioni.
                This extension prevents me from logging into Aliexpress even if I added the site to the exceptions
                  drylegend176 last edited by
                  Thanks for not working
