    Abdode flash player problem..
    5414
      tolispro last edited by
      Hi... http://i.imgur.com/rSuFZoP.png
      Take a look at the picture above,this happens at all videos(including Twitch livestreams) It says "Click to use abdode flash player" Also the chat on twitch does not load..This happens only at opera(google chrome works fine..)
        If it's "abdobe" - maybe it's a brand new thing Opera doesn't support yet? 🙂
        Seriously though, what's your Opera?
        Using plugins? Turbo/Offroad on?
          My bad..it actually says adobe.
            O'k then 😉 what about your Turbo settings? What connection do you use?
            Plugins up-to-date? Activated?
              I have no idea 😮
              Those are the plugins? http://i.imgur.com/ZWKsfA7.jpg
                They are extensions, I guess...
                Maybe, Plug-in (computing) - Wikipedia, the free encyclopedia.
                Well, type the following into your address-bar:
                opera://plugins
                and hit "Enter".
                After you get that (check what plugins are installed and which of them are activated), check the setting for the "Turbo" (or "OffRoad") mode.
                If the relevant plugins are there and activated (Adobe Flash Player, in our case), and the "Turbo" mode is on, then try switching it (the latter) off and check if the situation's changed.
                  They're all enabled http://i.imgur.com/tljxwVp.jpg
                    What about your connection?
                    Do you have your "Turbo" on?
                    Anyhow, what happens if you click on that thing your displayed in your OP? Does the video play or not?
                      The video plays..My turbo is on I think.. http://i.imgur.com/R8LW5KI.png
                        linuxmint7 last edited by
                        If 'Opera Turbo' is on, turn it off.
                          I turned it off and it works now,thank you 🙂
                          • X
                            xzraiderzx last edited by
                            Can this be fixed WITH Opera turbo?
                            Because my internet is shite and opera turbo helps alot
                            but it breaks things like twitches chat (Flash failed to load. Please contact twitch.tv with error information.)
                            and it does the click to use adobe flash player.
                              Yeah, its gonna break that stuff. With Turbo enabled it routes your content to Opera servers where they compress it and then send it to you. That breaks a lot of that stuff by its very nature. Really though, Turbo doesn't speed up your browsing, it just reduces the load. Its great if you have a metered connection but isn't really that effective if your internet is just slow.
