    Volume up - Boost your sound
    85
    129
    101065
      LuckyTanuki Banned last edited by
      This extension sucks. For some reason using it causes YouTube player to go into windowed fullscreen instead of actual fullscreen. Its obvious this shit's rating was boosted by bots. If the Ridiculous number of Russian comments, all with generic or nonsensical usernames didn't make that obvious enough.
      • HankHunter
        HankHunter Banned last edited by
        Yes, this extensions caused Youtube and other websites to not go into fullscreen mode but you can fix it by pressing F11.
        No need to talk bad about it because one a single mistake.
          L 1 Reply Last reply
          LuckyTanuki Banned @HankHunter last edited by
          @hankhunter Pressing F11 to Fullscreen the entire browser should not be the solution. I don't want the entire browser Fullscreened I want just that video im on to Fullscreen. The fact that this is still an issue after there are multiple other posts about the same thing shows a lack of care from the dev to fix it. Instead they are more focused on buying reviews.
            HankHunter 2 Replies Last reply
          • HankHunter
            HankHunter Banned @LuckyTanuki last edited by
            @luckytanuki I think you're pressing the wrong button on YouTube to full screen, you're probably clicking the miniplayer button (on top of the video), you should presss the full screen button in the button right of the YouTube video. Hope this helps
            • HankHunter
              @luckytanuki it's not the extension fault
                @hankhunter how can you say it's not the extensions fault when, I install the extension, it happens, and when I uninstall it, it doesn't happen...
                  HankHunter 1 Reply Last reply
                • HankHunter
                  @luckytanuki try my suggestion and see if it works
                    @hankhunter did you really just say that? You really think I don't know where the Fullscreen button on the YouTube player is... You are either a troll or a simp for this extension if you really think that I somehow magically don't know enough about YouTube.... Even though I'm trying to install extensions to enhance my experience....
                    • HankHunter
                      @luckytanuki it doesn't happen to me,it's a perfectly fine extension. I think you got alot of extensions and they're causing some type of conflict. I suspect you're some kind of dork, not trying out extensions which all work fine. But to shit in this comment section
                        @hankhunter it works fine for you. How about the many other comments saying they are having the exact same problem as me. Gonna say those aren't valid too just because YOU aren't having tbe issue. Also, I don't have any other extensions installed because I don't need any other ones. This is the first and only extension I've installed Because I only downloaded the browser about 2 weeks ago.
                        • HankHunter
                          @luckytanuki check again if your PC is not dealing with retarded user illness it's pretty common for people like you, going around and calling names to people who are helping you based only on some text, in which situation your not even providing anything sort of proper material that could be used to help. And I haven't even seen any comment suggesting that anyone has the same problem as you. Yon can keep posting here and make this extension look bad but it's not for all those people who are giving it a good review. Go search up on Google volume booster extension and download some other one and stop sticking to this one.
                          • HankHunter
                            @luckytanuki you just downloaded the browser and are arguing with some guy who was using opera for over 8years,
                              LuckyTanuki Banned @HankHunter last edited by sgunhouse
                              @hankhunter @raygon said in Volume up - Boost your sound:
                              I think there is a bug that prevents videos to go in full screen, while/after the volume booster has been used
                              Here's just one of many posts from 8 days ago you moron. But yea. Im the only one who is having this problem. How can you not see the multiple posts all saying the same thing. Are you sure your not the one with brain damage? It's not like they are hard to find. Hell the very first comment was about exactly this issue. Are you actually the dev on an alternative account that is getting butthurt at their extension being bashed for not fixing an issue MANY people are having.
                              • HankHunter
                                @luckytanuki you absolute parasite, their problem is not that it goes into a windowed mode it's just that it can't enter full screen mode, I am starting to think you're some sort of hired bit coin Assassin who is out here trying to run over people who are supporter this extension, like how do you even manage to do basic chores, haha ofcourse you don't cause you're a little cry mama baby. Don't try to associate other people's problems with yours just cause the problem shares a single word "full screen", you're like the person who complains about something that it's not right but still chooses to stay by it and keeps hating on it, like fr just quit this drama and touch some grass
                                  @hankhunter @volumebooster2 said in Volume up - Boost your sound:
                                  @potrenz: Firstly, open extension window, than change volume and hit F11. Fullscreen by hitting F11 is working.
                                  Look. More people saying you need to fully Fullscreen the entire browser tab instead of just the video player. You call me a parasite but whos the one sitting on extension forums all day simping for an extension with bought reviews XD. Ok bud. Maybe leave your reddit mod basement and touch a woman that isn't mom 🤡
                                  • HankHunter
                                    @luckytanuki looks like you're the one bos not getting the p anyway you can keep wasting your time here replying and taking shit, no one cares about your problem you can keep doing this shit, none of the stuff you said was true or had any real meanings, just that I don't know how to use internet so this extension bad like wth, get better than this,
                                      Rahmed11 last edited by
                                      can there be an option where you can increase BASS or make sounds sound classic
                                      ANDD i rlly want this to work on the Opeara GX side bar (Spotify)
                                        SUPPLEX last edited by leocg
                                        Extension is garbage. it does change the volume but also changes fullscreen mode to not work> Do Not Use
                                          decoytrix last edited by
                                          Is there a reason or setting that interferes with addons like this with the Opera GX browser? I know it isn't this specific addon because none of the volume booster addons seem to work for me. And it also only seems to be an issue with youtube, other sites seem to work fine.
                                            viczav last edited by
                                            The extension works as intended, but there's a bug that prevents to enter in 'Fullscreen Mode'. I hope you fix it!
                                            Thanks in advance~
