    Reddit Problem: Your Connection Is Not Private
      I just switched to Opera GX and when i went to www.reddit.com or any reddit post it says your connection is not private, please help me
        @juniorzgt Check date/time settings on your computer.
        If date/time settings are not preserved after a shutdown, then replace BIOS battery.
        End if this error is caused by an expired SSL certificate. You need to update the SSL certificate to a newer one. Watch the detailed tutorial here:
        How to fix "your connection is not private" error on chrome
        Fix SSL Certificate errors:
        NET::ERR_CERT_DATE_INVALID
        NET::ERR_CERT_AUTHORITY_INVALID
        ERR_CERT_COMMON_NAME_INVALID
        ERR_TOO_MANY_REDIRECTS
        ERR_SSL_WEAK_EPHEMERAL_DH_KEY
        ERR_SSL_VERSION_OR_CIPHER_MISMATCH
        ERR_BAD_SSL_CLIENT_AUTH_CERT]
