    Sound Booster
    39
    42
    31384
      Vinorixus last edited by
      It's an awesome extension, but I really wish there was an interface option for a normal bar
      The dial option is extremely difficult to control - if you hold it with the mouse it starts drifting on its own and changing the volume, so the only way to get to where you want is to click, swipe fast and hope you land there. Most of the times, you wont and you'll have to do multiple adjustments. It is quite frustrating.
      It is the only extension that does this though, so despite the UI pain, thank you for making it 🙂
        ruslanaluhio last edited by
        Great, but so difficult for for perception. I installed this one - https://addons.opera.com/en/extensions/details/volume-up-boost-your-sound/
          when you up the volume, you lost the fullscreen mode on a video
            V 1 Reply Last reply
            volumebooster2 @Guest last edited by
            @guli88: Use this extension which support fullscreen mode https://addons.opera.com/ru/extensions/details/beats-volume/
              H 1 Reply Last reply
              Almost game me tinnitus. It doesen't work on speaker, but then i put the headset on and scares the shit out of me. If i could -0 star
                colles addon
                  ashura-uchiha last edited by
                  it doesnt work properly now at the begin it was perfect but now everytime its on i got bad audio quality and it stutters
                    one of the best add on ,
                    doesn't need very good handsfree/phone specially for videos with low volume.
                    600% is superb.
                    that full screen issue is there. but whatever
                      showpassword Banned last edited by
                      The best addon is https://addons.opera.com/en/extensions/details/volume-up-boost-your-sound/
                        cems last edited by
                        Can we play with voulume in a bar instead of button please? Bar is way more comfortable. And 4 buttons that makes volume %100, %150, %200 and %300. So It can be a shortcut which means we won't have to play with button.
                          Polla69cock last edited by
                          This is legit. 10/10
                          • Oakadiel
                            Oakadiel last edited by
                            Seria ótimo se eu pudesse usar esta extensão e ver meus vídeos em tela cheia. Mas infelizmente, depois de ter ativado ela, não conseguia mais ver vídeos sem que ficassem as abas de endereço e de fechar o navegador, aparecendo no topo. Depois que desativei a extensão voltou a funcionar.
                              A Former User @Oakadiel last edited by
                              @oakadiel: pressiona F11 quando estiver na tela cheia, isso vai ativar o modo tela cheia do Navegador e vai resolver teu problema, quando quiser voltar ao normal é só pressionar F11 novamente.
                                Oakadiel 1 Reply Last reply
                              • Oakadiel
                                Oakadiel @Guest last edited by
                                @hipp1e Eu já havia tentado isso tb. Se só deu este problema para mim, creio que foi incompatibilidade com outra extensão. E pra eu não ter que tirar alguma extensão que tenha mais funções, prefiro usar outra que achei que é pior no sentido de praticidade para usar, mas funciona em tela cheia. Achei uma que vc clica no botão da extensão e aumenta gradualmente e qd vc quer baixar o volume, tem que resetar e o volume volta ao normal (é o lado negativo), mas vejo os vídeos em tela cheia sem problemas.
                                  Rangrid last edited by
                                  love this, now i can make my ears bleed without having to worry about max volume 😃
                                    mericdevon last edited by
                                    perfect!
                                      Scout2007 last edited by
                                      it crashes when i try to add it
                                        Appet last edited by
                                        can you fix the annoying wheel thing, it doesnt work right with my trackpad, maybe make a little straight line somewhere near the wheel that you pull down to change the volume
                                          max8555 last edited by leocg
                                          how can i boost the volume on it becuse when i click on the speaker on the bar it mute it .
                                            stepwolf78 last edited by
                                            very useful 😉
