    Built-in adblock doesn't work correctly
    Opera for Android
    11
    27
    19158
      @naheed I mentioned earlier that the so called "acceptable ads" is disabled and ads are still showing.
        nsx last edited by
        The funny thing about this debacle is on actual youtube video it pretends to respect whatever by auto mute the video and require you to click on it, even though the ad immediately preceding it blasts at full volume automatically.
          Is August 2021 and ads are still showing up on Opera for Android with the blocker enabled.
            @jechf hi, OP here. I grew tired of Opera support pretending they are going to do something with issues related to Android and desktop versions of Opera and switched to Vivaldi on both platforms - totally recommend it! It's the same webpage rendering engine (at least on desktop) but much more configuration options! As for Android - not only its built-in adblock allows you configure what to block, how, where as well as import adblock lists from the sources you specify, but also allows you to have an external ad-blocking app (like AdGuard) filtering https traffic of Vivaldi (which Opera doesn't allow for some reason and prevents you from browsing pages!). Give it a try!
              L 1 Reply Last reply
              lucasbs @Guest last edited by
              I also recommend Firefox, for the exact same reason:
              It supports the uBlock addon, which allows to block any element on the page.
              It also supports custom ad list and tracking list.
              Opera is way behind on this area. Way behind. A lost war
                A Former User @lucasbs last edited by
                I have found that firefox doesn't work correctly on some sites, has sometimes huge memory usage, the latest user interface is ugly, it has issue playing videos on some sites, and the mobile version is slow. I don't recommend using firefox. Instead I recommend using another chromium based fork, like vivaldi or brave.
                  lucasbs @Guest last edited by lucasbs
                  @sbernecchia
                  Your points may or may not hold truth
                  In the end, it's up to the user.
                  In my case, the addon ability overweights the app's... weight and unstability.
                  The block element function of uBlock, for instance, allows me to remove so much about the pages I visit frequently, that it gets more lightweight than Opera
                  I can even remove paywalls !
                  Well...
                  What we probably agree on is: good bye Opera
