    Shortcut for "Toggle pin"
    • H
      hatchi last edited by
      Hello,
      I use Opera Mail and couldn't find "Toggle pin" or like it on "Mail window" view of shortcut configuration.
      Is there any way to assign some key to toggle pin state?
        Look in ui/standard_menu.ini in the program files directory. Under the "Mail Item Popup Menu" section, you'll see the command.
        For the keyboard shortcut, you'd use:
        Flag message, 1 | Flag message, 0
        (In the future, for threads about Opera Mail, please prefix the subject with "Opera Mail - ". Thanks)
        • H
          Succeeded. Thank you very much.
          (Japanese translation is little bit strange - it is translated as "pin", not "flag")
          Understand. I'll do it.
          Regards,
