    My Speed dials suddenly deleted
    Opera for computers
    44
    89
    72504
      Fetherator last edited by
      It seems there is a new option in Opera to hide the Speeddial.
      Im from Germany and my speeddials disappeared after updating Opera 2 Days ago. I found out that there is a new option under the advanced tab and then go to startpage settings, there u will find a setting: hide speeddial or equal ( i have the german version).
      This setting seems to be set to ON after update on opera, i changed it and boom back are my Speeddials. But still there is one more problem, after closing opera and restarting it the setting switches back to Hide Speeddial.
      I hope this will help a little.
      • Z
        zotlonpennsyl last edited by
        Same problem for me today on Opera mobile. Everything's gone and instead I had two dials on there that I didn't even add. This "adware" behavior of adding random icons to my dial was annoying me for a while now so I switched to a different browser as well. gg
          tshalf last edited by tshalf
          The problem has returned. I lost all from my Speed Dial on the PC.
          It happened yesterday, when I tried to return the button "Opened Tabs" on the left panel(it disappeared, maybe after last Opera update). I logged out from synchronization and logged in again. After very slow synchronization, I got the button "Opened Tabs" again, but an empty Speed Dial.
          The folder on https://www.sync.opera.com/speeddials is empty.
          And when I ran my PC today I've found that the button "Opened Tabs" has disappeared again.
            T 1 Reply Last reply
            tshalf @tshalf last edited by
            @tshalf And when I ran my PC today I've found that the button "Opened Tabs" has disappeared again
            Correction, "Opened Tabs" did not disappear again.
              tshalf last edited by This post is deleted!
                Scarab last edited by leocg
                [Solved] Just signed in to Opera Sync on my Desktop, which is my primary computer, after signing in to Opera Sync on my laptop which is basically a fresh install of Opera. Once the synchronization was completed, all of my Speed Dials on my Desktop were suddenly deleted. I could not tell if the same deletion occurred on the Laptop, as there were no Speed Dials loaded as yet on that machine.
                On my Desktop, after failing to find a solution online with a cursory Google search or in these Forums, it was easy enough to resolve, at least in my particular case, by simply opening the Bookmarks inside a new tab in Opera, then selecting the entirety of what appeared to be a new Speed Dials subfolder (which for me was located near the bottom of the Bookmark tree structure, then performing a right-click to open the context menu and selecting "Copy", then finally clicking on the main/parent Speed Dial folder (located at the top of the Bookmark tree structure-which was empty- under the Bookmarks Bar folder) and performing another right-click for the context menu and selecting "Paste".
                All Speed Dials returned to my Speed Dial page on my Desktop. Went to laptop, closed and restarted Opera, and waited nearly an hour (just in case) before reloading Opera. No Speed Dials are there, even after assuring the Synchronization was signed in on the same account. I'll just copy and paste the same way after exporting my bookmarks from my Desktop and Importing them into my laptop.
                Problem solved.
                  opera.png On the Speed ​​Dial page, right click on the page and choose the bookmarks option (above the history option) you should be able to see a new screen with your favorites. opera 2.png I hope this helps you
                    2020 Not only is their forest fires, the sun was red, a CV19 pandemic, riots, the Olympics were cancelled. But to top that off my Opera Speed dials are not working.
                    They work on my laptop fine (Tho I haven't fully turned the power off yet) But on my desktop, they disappear each time I turn off and do not link with my laptop even tho I sync them with the same email address?
                    I just started using opera and every other feature that works like the left sidebar is a blessing and I don't wanna lose. But if this keeps up I will have to migrate to another browser?
                    P.S I don't seem to be able to stack tabs either? I try dragging them onto each other but that does not seem to work?
                      A Former User last edited by sgunhouse
                      to restore it go to the syncronitation tab next to downloads tab and then sign in as and your email will appear click on it then log in and then click on see syncronysed data and then you will be able to restore any of your data
