    xdg-open magnet links opera 58 problem
    Opera for Linux
    xdg-open magnet
    3759
      Hi,
      I'm using opera 58.0.3135.90 with ubuntu 18.10. When i'm trying to open magnet links, it open pop up lunch xdg-open. But when i click to lunch it don't do a thing.
      In chrome it's work like it should.
      gio mime x-scheme-handler/magnet
      Default application for “x-scheme-handler/magnet”: qbittorrent.desktop
      Registered applications:
      qbittorrent.desktop
      Recommended applications:
      qbittorrent.desktop
      In /var/log/syslog i'm getting message:
      opera_opera.desktop[4320]: user-open error: Supplied URL scheme "magnet" is not allowed
        What does
        xdg-mime query default x-scheme-handler/magnet
        return?
          @jimunderscorep
          qbittorrent.desktop
          The problem is not in defaults. Chrome work fine with same xdg-open.
            Are you running the snap version of opera?
              ? 2 Replies Last reply
              @jimunderscorep
              Yes.
                @jimunderscorep
                Update: I have removed the snap version and installed from http://deb.opera.com/opera/ stable repository. Everything is working now. I have copied profile from snap version. So it seems like problem was in snap version of opera.
                jimunderscorep thank you.
                  That's what I was about to say. Snap apps, in general, have restrictions on what they can and can not access from the main os. As it seems, by default, the snap opera can not access the association for the magnet:// links.
