    Opera doesn't remember window size and position if it was closed without any tabs (except Speed Dial) on Linux Mint
    Opera for Linux
    8355
      lh-mouse last edited by
      I have a habit to maximize the window of my browser. Since on Windows Opera remembers its last-closed window status, I don't have to maximize it by hand every time I start it. However, on my Linux Mint laptop, Opera remembers window status only when it was closed with at least one open tab. In other words, if it is not the case, Opera always starts in a non-maximized, centered window. This seems a bug. Would you please fix it? Thanks in advance.
        ? D 2 Replies Last reply
        I can confirm this issue happens on my PC as well. Linux Mint 18.3, 64-bit.
          mmichel last edited by
          Then you can fill a bug report 🙂
          Thanks for your time
            this has been around for what seems like years.
            happens on Mint and Ubuntu for me
              A Former User @lh-mouse last edited by A Former User
              @lh-mouse said in Opera doesn't remember window size and position if it was closed without any tabs (except Speed Dial) on Linux Mint:
              you can 'fix' this in the settings by ticking "continue where i left off'
              [i realize its not a ideal way to fix it]
                L 1 Reply Last reply
                lh-mouse @Guest last edited by
                @ultravio1et I always have it checked. Please read the sentence I emphasized in the original post.
                  @lh-mouse i must of got confused.
                  your right, i've just started up Opera with only the speed dial its its centered on screen not maximized. certainly not how i left it
                  [ubuntu 18.04]
                    Read here:
                    https://forums.opera.com/topic/22812/start-opera-in-fullscreen-in-command-line
                    https://forums.opera.com/topic/23065/opera-48-0-will-not-open-in-maximized-window
                    https://forums.opera.com/topic/20897/opera-does-not-remember-window-size
                      despotveliki @lh-mouse last edited by
                      @lh-mouse
                      I know it's an old thread, but hey.....
                      For me, two solutions are working:
                      1 - For MAXIMIZED window edit Opera launcher -->right click on icon/ Properties/Application tab/ field Command: opera %U --start-maximized
                      2 - For CUSTOM window size edit Opera launcher -->right click on icon/ Properties/Application tab/ field Command: opera --window-position=118,64 --window-size=1682,951 %U
                      That sizes are actual settings for my desktop.
                      I'm on KDE Neon (Bionic 18.04), Opera 56.0.3051.31
                      Cheers
