    startpage.com as default search engine
      I would appreciate, if startpage.com was the default search engine. Also I wish an optimal cooperation between startpage.com and Opera.
      • acidinmyfridge
        acidinmyfridge last edited by
        i'm using custom new tab add-on
        https://addons.opera.com/en/extensions/details/custom-new-tab-page/?display=en
        and startpagesearch add-on
        https://addons.opera.com/en/extensions/details/startpage-search-extension/
        as a workaround for that.
        You think you know, but you have no idea.
          zalex108 last edited by
          If someone want to try it, here is a workaround.
            @cbuth said in startpage.com as default search engine:
            Yes. I've been waiting for this to happen - is there an ETA when startpage when we will be able to make startpage a default search engine?
              That would be nice. I added a shortcut to StartPage in the Speed Dial to make it easier to access.
