    Viewing total Opera processing power
      james438 last edited by
      Is there a way to view Opera's total processing power usage? For example the Windows Task Manager lists several entries for Opera; in my case 27. In the browser Shift+Esc has more detailed information, but still doesn't list the processing power as a whole.Is there a way to view the processing power usage as one number?
        Interesting
          You cannot from inside the browser or afaik from Windows' default task manager. You can use a better task manager though like Process Hacker (I use it for years) http://processhacker.sourceforge.net/ , there in the Options/Advanced make sure you that "Include CPU (and other) usage of children in collapsed processes" is ticked. You can also see by that the total amount of RAM used by all those Opera processes.
          Cheers 🙂
            xirit32: Very handy tool. Thank you. It appears that Opera is using 1.79 GB of RAM with four tabs open. After restarting Opera dropped it to about 1.5 GB.
