    M2 right click menu
    13496
      stng last edited by
      @emc
      Unfortunately, you can't emulate pressing the "Enter" button or carrying down to new line with Opera's commands.
      But you can use external utility NirCMD (freeware, doesn't occuppy system memory, Windows only).
      1. Download NirCMD: http://www.nirsoft.net/utils/nircmd.html
      2. Install NirCMD (use Administrator's rights)
      3. Edit your "To David" item in your Opera's menu configuration:
      [Mail Body Popup menu]
      Item, "To David"=Forward mail & Insert, "david@david.com" & Focus Next Widget & Focus Next Widget & Focus Next Widget & Focus Next Widget & Delay, 100 & Insert, "Hi David, this is the weekly report. Tks!" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkeypress enter" & Delay,200 & Insert "Best regards edmond." & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkeypress enter" & Delay, 500 & Send mail
      P.S.: "Execute program, "c:\windows\nircmd.exe","sendkeypress enter" " - emulates ENTER button.
        emc last edited by
        Thanks again Stng !!!!
        Old Opera is GOLD...............
        Thank you
        Edmond
        P.S. I will advise David he need to get use to read mail in one row in future............
          emc last edited by
          Hi Stng,
          Thanks to the explanation & now I could be able to manage it everything you shown me.
          New question, if I am to instruct M2 to:
          • Focus email body
          • High-light the 1st 3 rows. ( I may need to be specific to high-light 1st 4 rows or 5 rows )
          What would be this command ?
          I understand the Focus next widget... or Focus previous widget in order to make it Focus to mail body.
          I just do not know that is the command on ' high-kighting '., the 1st few rows in the mail body.
          and... what is the command on high-lighting a specific ' numbers ' of rows ?
          I am trying to highlight the:
          ---- forward message -----
          sender: xxxxx
          To: xxxxx
          date: xxxxxx
          Subject: xxxxxxxxx
          Thank you!
          edmond.
            stng last edited by
            @emc
            You need to emulate hold down of SHIFT keyboard button. It's possible only with NirCMD external utility.
            For compose window with enabled HTML-editing:
            Focus next widget & Focus next widget & Focus next widget & Focus next widget & Focus next widget & Go to start & Execute program, "c:\windows\nircmd.exe","sendkey shift down" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkey end press" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkey down press" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkey down press" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkey down press" & Delay,200 & Execute program, "c:\windows\nircmd.exe","sendkey shift up"
            Yeah, it's pretty much complicated but it works.
            What Nircmd does: pressing and holding shift, pressing end, pressing down, pressing down, releasing shift key.
              emc last edited by
              Thank you stng...............
              It's really a bit frightening for me to do with nircmd ( as I have tried before without success.... )
              Thanks anyway to your time......... !!!
              Thank you!
              Edmond.
                stng last edited by
                You can use it because it's complete solution.
                Here is instruction how to install NirCMD: http://www.blogtechnika.com/setup-use-nircmd-command-line-tool/
                  emc last edited by
                  Thanks stng !!!!
                  Done it !!!
                  Now it can............. highlight 4 lines ( and stop there )
                  Thanks much stng !
                  Edmond.
                  P.S. what other command in NirCMD useful in Opean M2 ? ( if you have a web page link about it.... )
                    emc last edited by
                    HI stng,
                    On my other copy of Opear, it does not hightlight the first few rolls in body of email. I saw the cursor jump a few line , it just does not hightlighting the rows in the mail body:
                    Blah blah blah... Focus Next Widget
                    & Execute program,
                    & Delay,200 & Execute program, "c:\windows\nircmd.exe", "sendkey end press"
                    Above does work in some of my other copy of Opera when some other copy not.
                    Highlighting action should be sendkey down press ? And what would be the cause when some Opera M2 doesn't listen to these command ?
                    Thank you
                    Edmond.
                      stng last edited by
                      Hello
                      "sendkey down press" simply emulates pressing of "down" key.
                      "sendkey shift down" allows to emulate holding down "Shift" button.
                      While Shift button in a pressed state(when the button Shift is holded by NirCMD), you can use "sendkey shift down" to highlight required amount of text lines.
                      Keyboard cursor should be placed correctly (in correct field and in correct line) before NirCMD's macro(with "sendkey" arguments) execution.
                      Also, do not forget to use "& Go to start " command after the last "Focus next widget" command. "Go to start" moves keyboard cursor at the beginning of mail body.
                        emc last edited by
                        Hi Stng,
                        In the mail body , if I am to delete the first 1 or 2 empty lines ( before the )
                        ------- forwarded mesage ---------
                        What is the command if using Nicmd ? ( say delete first 3 empty lines )
                        Thank you
                        Edmond.
                          stng last edited by
                          @emc
                          Commands for deleting first three EMPTY lines(lines w/o any characters except next line carriage):
                          Focus next widget & Focus next widget & Focus next widget & Focus next widget & Focus next widget & Go to start & Delete & Delete & Delete
                            emc last edited by
                            Hi all,
                            I have done that all okay since above.
                            Just a small question to why:
                            Submenu, "Forward to my home"Show popup menu,,,, "Mail Accounts""
                            ===> When right click , submenu item shows envelope icon.
                            Item, "Forward to my office"=Copy & Deselect all & Forward Mail & Insert, "my office@my office.com" & Delay, 5000 & send mail
                            ===> When right click , normal forward item shows only arrow icon ?
                            How I can also make the 2nd one showing envelope icon as well ?
                            Thank you
                            edmond.
                              stng last edited by
                              @emc
                              Use this
                              Item, "Forward to my office"=Copy,,,,"Mail Accounts" & Deselect all & Forward Mail & Insert, "my office@my office.com" & Delay, 5000 & send mail
                                emc last edited by
                                Hi stng,
                                Thank you !
                                Would like to ask again as the question was, how to put the ' envelope ' icon next to the item from right click menu ?
                                my item on the right click menu is:
                                Item, "Forward to my office" DI_IDSTR_M2_MAILVIEWTOOLBAR_FORWARD=Forward mail & Insert, "myoffice@myoffice.com" & Delay, 100 & Send mail
                                I could see, sub-menu has envelope icon next to it., but above item only has an ' arrow ' kind of alike icon next to the item name.
                                This one , the sub-menu has an ' envelope ' icon:
                                Submenu, "blah blah blah",blah blah blah="Show popup menu,,,, "Mail Accounts""
                                Thank you
                                edmond.
                                  emc last edited by
                                  Hi,
                                  Could someone please let me know what was missing to the below:
                                  When using Nircmd in M2 compose..........
                                  ( right click context menu I have assigned the below )
                                  Go to line start & delay, 2000
                                  & Delay, 200 & Go to start & Delay, 2000
                                  & Execute program, "c:\windows\nircmd.exe","sendkey shift down" & Delay, 2000
                                  & Execute program, "c:\windows\nircmd.exe","sendkeypress down" & delay, 2000
                                  & Email increase text size
                                  The problem is:
                                  The compose area is not "selected" as above sequence supposed holding the shift key & down & highlight 1 - 2 rows.
                                  but I found the shift key is indeed trigger to press down., I have to press the keyboard shift key to release it.
                                  Why the rows of mail body not select & highlight ?
                                  Thank you very much.
                                  Edmond.
                                  The
