    Speed Dial Shortcut in Opera 18?
      I just updated from Opera 16 12 to 18, and ctrl+[1-9] no longer seems to work to quickly open the pages saved to my Speed Dial. Is there any way to set up a keyboard shortcut for this? It seems like the update made the Speed Dial options a lot less accessible, they'd might as well just be bookmarks at this point.
        Originally posted by mikeoshay:
        I just updated from Opera 16 to 18
        Those shortcuts did not work in Opera 16 either.
          My mistake, I had a folder for Opera 16 and thought that was the other version I was using, but it was actually 12. Comment edited, but I'd still like to find a solution. It'd be alright if they replaced it with the standard browser shortcuts of Ctrl+1-8 = first-eighth tabs and Ctrl+9 = last tab, but as it stands they're just functionless.
            nelldor last edited by
            Hey,
            I'm here to actually ask about the same problem. Currently I'm using version 12 and I decided to try the new Opera 18.
            With grinding teeth I decided to settle with the missing bookmarks and was about to start using it anyway, but then I found out that the ctrl + (1-9) aren't working.
            Is there any plugin or any solution to this? I mean... there is plenty of other shortcuts and I don't see any reason why this one shouldn't work.
            Thanks in advance,
            Tom
